This is the second version of the CamemBERTa model, which is based on the DebertaV2 architecture trained with the Replaced Token Detection (RTD) objective. The new update includes: 1) Much larger pretraining dataset: 275B unique tokens (previously ~32B). 2) A newly built tokeniser based on WordPiece with 32,768 tokens, addition of the newline and tab characters, support emojis, and better handling of numbers (numbers are split into two digits tokens). 3) Extended context window of 1024 tokens
If you use this work, please cite the following:
@unpublished{antoun:hal-04789028,
author = {Antoun, Wissam and Kulumba, Francis and Touchent, Rian and Villemonte de La Clergerie, Eric and Sagot, Beno{\^i}t and Seddah, Djam{\'e}},
note = {working paper or preprint},
title = {{CamemBERT 2.0: A Smarter French Language Model Aged to Perfection}},
year = {2024},
url = {https://hal.science/hal-04789028},
